DID problem
Discussion in '3CX Phone System - General' started by you2web, Oct 8, 2009.
  1. you2web
    Sep 21, 2009
    15
    Hey
    I have successfully configurated 3cx with our sip trunk provider.
    I have just one little question - problem
    I get 10 numbers and 4 channels from my provider. Everything works well exept when i call let say from number 05590 345 700 caller receive right number, but if i call from 05590 345 701 caller receive also same number ( 05590 345 700 ) instead of 05590 345 701.
    When i look into the server log files i found out that every outbound call has the same sip:mylogin@ip instead of sip:mylogin700(701,etc)@ip
    Can somebody help me with that
    Thank you
    Uros
  2. satman1w
    Jan 14, 2008
    12
    Uroše prijatelju,
    In 3CX Phone System Mahagement Console (PSMC) choose 3CX Phone System / Extensions / extension number you want to set.
    In "Edit Extension" window, choose "Other" tab, and in the "Outbound Caller ID" enter the number you want to present to the called party.
    Did it help?
    Best regards
  3. you2web
    Sep 21, 2009
    15
    Ni nič bolje
    I already have that , but no luck
    same thing
    But thank you for replay
  4. comresource
    comresource Member
    May 22, 2009
    303
    You may also need to tweak the outbound parameters depending on your Sip Provider. For instance I had to change "From: User part" to "OutboundCallerID" in one case.
  5. satman1w
    Jan 14, 2008
    12
    The number you enter must be in the same format your provider uses, so look in the log and see the format of number when you receive the call from outside caller. Then enter the number as I wrote in last post but mind the format.
    I had the same problem, and until I entered the number in appropriate format, outbound call always presented the same (carrier) number.
    I can't think of any other reason for your problem.
    Ugodan vikend, pozdrav iz Zagreba :)
  6. you2web
    Sep 21, 2009
    15
    I did that
    Please check pic ( i have cleared id )
    I think it is correct format
    And please tell me how can i correct format
      File size:
      181.1 KB
      706
  7. satman1w
    Jan 14, 2008
    12
    Now I believe that my answer will not help because until now you have probably tried all the possibilities.
    In my case it looks like this +3851nnnnnnn.
    In your case probably +3861nnnnnnn if you are in ljubljana, slovenia....
    Stay well
  8. you2web
    Sep 21, 2009
    15
    Thank you for answers and
    pozdrave v zagreb
    LP
    uros - kranj
