DID ringing but no voice and disconnected when answering
Discussion in '3CX Phone System - General' started by dmanolis, Jul 7, 2007.
  1. dmanolis
    Jul 7, 2007
    I have setup a DID number from ipcomms.net. The DID rings on my extension but when answering it there is no voice and it disconnects. I dont know what is going on? If anyone can help it will be greatly appreciated.
    Thank You,.
  2. dmanolis
    Jul 7, 2007
    Hi. I guess wasnt very clear in my previous post. The phone rings and when you pick up you here 2 seconds of voice and then it drops the call. Ipcomms.net does not require authentication on there lines. I really dont know what is wrong. Please help.
    Thank you
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i also use did from didx.org it is ok - the only issue i have with this is it abears as unregistered but it is full functional.
    it try to register evey 10 min but no other trouble with this
    CM113006] Registration of sip:442030263***@DIDX.net has failed; reason=Not found
    what you can check is if you have suport reinvite enabled
  4. dmanolis
    Jul 7, 2007
    Ok. Resolved the issue on the incoming calls. But now how can i separate the DID's goint to different extensions. They all ring at the same extension, even though they are told to ring otherwise. VOIP is frustrating.
  5. Anonymous
    Anonymous Guest
    Each DID can have its own line, that should solve the problem.
    Than use Call grouping to determine what extensions you want to have it ring, or just bind it to one extension.
    The number mask of the DID is used to determine the difference, starting from the back. (from memory I have to look that up actually).
  6. dmanolis
    Jul 7, 2007
    So if my DID is 718-545-7895 i would have to put that in backwards?
  7. Anonymous
    Anonymous Guest
    No no, lets not go there :).
    I am at a client site atm, but from memory it checks from right to left.
    So 718-545-7895 you could split it up as
    7895 as did one
    5457895 as did two
    7185457895 as did three
    Wasn't there something mentioned on the DID config screen about that?
    ===========edit===================
    Ok almost :).
    *7895 as did one
    *5457895 as did two
    Are all seen as the same number.
    you have to make sure you got the number in the "To" field so if you ISP provides you with 3 different DID numbers you have to make sure that the system looks into the TO field and route accordingly.
    My guess is that your config looks at the wrong field to identify the line. (unless your ISP/VSP does not provide the line ID).
