Solved DID routing not working - PBX Free
Discussion in '3CX Phone System - General' started by Aidaca, Dec 16, 2017.
Tags:
  1. Aidaca
    Dec 16, 2017
    5
    I am using VoiceMeUp as my SIP. I have 2 DIDs but all calls route to the default IRV. I have seen threads about the DID not being identified properly. Unfortunately the call log doesn't provide enough info for me to see what the actual DID is that's being passed.
    Could be something else but I'm guessing it has something to do with the DID label I'm using.
    Appreciate any help
    11,073
    323
    Have a read through this...
    https://www.3cx.com/docs/manual/inbound-rules/
    There is a troubleshooting section at the end, with information on identifying the DID number being sent in the log. It may be that your provider isn't sending DID information. Did you specify that requirement when you applied for the service, or, are you just assuming that it is being sent?
    YiannisH_3CX likes this.
  3. Aidaca
    Dec 16, 2017
    5
    Appreciate the quick response. Using the log I was able to see the DID being passed. Corrected my SIP Trunk with the DIDs being passed and all is good.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Glad the issue has been resolved and thank you for updating the thread with your solution
