DID Switchboards into 3CX
Discussion in '3CX Phone System - General' started by binary1, Jun 2, 2009.
  1. binary1
    May 4, 2009
    43
    Hi, I've got a VOIP provider which has DID Switchboard allowing multiple numbers to be "redirected" to the main account number.
    How do I capture it in 3cx and then do the appropriate routing to the correct extension number?
    The DID features in 3CX only has it for the analog pstn lines. This one is from the VOIP line.
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    In the properties of the VOIP provider you can specify all the numbers associated with the service - define them there and then use an inbound DID rule to route the particular number to the correct destination
  3. binary1
    May 4, 2009
    43
    apologies can you be a bit more specific?
    Do I get it done at the source ID tab?
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Not at the Source ID tab - at the DID tab next to it.
    Use the DID tab to enter all numbers that will be coming in from the VOIP provider. Once you enter the list you will have an entry under the VOIP provider for each incoming number - this is where you can set up your routing to specific locations.
