DID
Discussion in '3CX Phone System - General' started by Heath, Aug 17, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    116
    I have my SIP Trunk provider setup in the SIP Trunk Tab.. I have the GreenDot that its connected... I have 3 DIDs that I put in the DID tab.. In the inbound rules, I have set 2 are to ring groups, and 1 is set for a particular extension.. However when I call the DID from another phone, nothing happens and its not ringing on the phone.. when I call from my cell, said the number has been disconnected... My SIP is flowroute, and I checked all 3 are set to route to my PBX IP address. I can't find anything else why the DID's are not working...
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    910
    145
    Well you didn't mention if you saw the call hit the PBX but it sounds like the number is not 'active' or not properly routed at the Flowroute level. Even an improperly configured DID (at the 3CX level) would show the incoming call attempt in the logs. Flowroute support should be able to help.
  3. Heath
    Heath New Member
    Aug 12, 2017
    116
    No the call is not hitting in the log. But what is now interesting in the sip trunks. For kicks and giggles. In the general tab I put one of the DID's under main trunk and now only that DID worked. The other 2 are not. I have the DID's setup in the inbound rules and still says disconnected when I dial. But if I put then one of the other DID under main trunk then that DID will then work and the other 2 disconnected.
  4. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,092
    165
    Instead of using the full ddi number in the inbound rules , use wildcards
    For example if your ddi numbers are 8912363 and 8912364 use *2363 , *2364
