Re: Fax Server
Here is a full log copy. How am I looking here?
26-Jan-2013 20:08:22.973 [MS105000] C:2.2: No RTP packets were received:remoteAddr=127.0.0.1:10002,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7002
26-Jan-2013 20:08:22.973 MSLogReports
26-Jan-2013 20:08:22.862 L:2.2[Fax] Sending: OnSendResp Send 200/BYE from 0.0.0.0:0 tid=3942F4F Call-ID=ZjY4NDhjNmM5MDcxMGY3OTYzMjVhZTlkNGNjNDVhMDk.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK3942F4F
Contact: <sip:
[email protected]:5060>
To: "4Twelve-Solutions Fax:"<sip:
[email protected]:5060;nf=e>;tag=f235a854
[email protected]:5060;user=fax>;tag=72-2125
Call-ID: ZjY4NDhjNmM5MDcxMGY3OTYzMjVhZTlkNGNjNDVhMDk.
CSeq: 3 BYE
Content-Length: 0
26-Jan-2013 20:08:22.862 SendMsg from "4Twelve-Solutions Fax:"<sip:
[email protected]:5060;nf=e>;tag=f235a854 to <sip:
26-Jan-2013 20:08:22.758 L:2.2[Fax]: Terminating targets, reason:
26-Jan-2013 20:08:22.758 Leg L:2.2[Fax] is terminated: Cause: BYE from PBX
26-Jan-2013 20:08:22.758 Terminated from <sip:
[email protected]:5060;user=fax>;tag=72-2125 to "4Twelve-Solutions Fax:"<sip:
[email protected]:5060;nf=e>;tag=f235a854; reason: LocalBye
26-Jan-2013 20:08:22.758 L:2.2[Fax] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=7c0e7c35d72eb316 Call-ID=ZjY4NDhjNmM5MDcxMGY3OTYzMjVhZTlkNGNjNDVhMDk.:
BYE sip:
[email protected]:5100 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-7c0e7c35d72eb316-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 2 BYE
Content-Length: 0
26-Jan-2013 20:08:22.758 SendMsg from "4Twelve-Solutions Fax:"<sip:
26-Jan-2013 20:08:22.758 L:2.2[Fax] Sending: OnSendResp Send 488/INVITE from 0.0.0.0:0 tid=68C017F2 Call-ID=ZjY4NDhjNmM5MDcxMGY3OTYzMjVhZTlkNGNjNDVhMDk.:
SIP/2.0 488 Not Acceptable Here
Via: SIP/2.0/UDP 127.0.0.1:5100;branch=z9hG4bK68C017F2
CSeq: 2 INVITE
Content-Length: 0
26-Jan-2013 20:08:22.757 [CM503008]: Call(C:2): Call is terminated
26-Jan-2013 20:08:22.757 L:2.2[Fax]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
26-Jan-2013 20:08:22.755 Blocking refers for the Call(C:2)
26-Jan-2013 20:08:22.755 Call(C:2) is terminated
26-Jan-2013 20:08:22.754 L:2.1[Line:10000<<+18009806858]: Terminating targets, reason:
26-Jan-2013 20:08:22.754 Leg L:2.1[Line:10000<<+18009806858] is terminated: Cause: BYE from PBX
26-Jan-2013 20:08:22.751 Terminated from <sip:
[email protected]>;tag=3568237698-887444 to <sip:
[email protected]:5060>;tag=e326f011; reason: LocalBye
26-Jan-2013 20:08:22.750 L:2.1[Line:10000<<+18009806858] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=9408134bba435565
[email protected]:
BYE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-9408134bba435565-1---d8754z-;rport
Max-Forwards: 70
Route: <sip:209.216.15.70;lr;ftag=3568237698-887444>
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 3 BYE
Reason: SIP;description="Application Rejected Sdp(usually no common codec)"
Content-Length: 0
26-Jan-2013 20:08:22.750 SendMsg from <sip:
[email protected]:5060>;tag=e326f011 to <sip:
26-Jan-2013 20:08:22.750 Offer is rejected on Leg L:2.1[Line:10000<<+18009806858];
OnOfferRejected Recv 488/INVITE from 209.216.15.70:5060 tid=fd15c526b2025878
[email protected]:
Via: SIP/2.0/UDP 10.1.2.10:5060;received=72.94.24.236;branch=z9hG4bK-d8754z-fd15c526b2025878-1---d8754z-;rport=5060
Record-Route: <sip:209.216.15.70;lr;ftag=3568237698-887444>
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Allow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Call-Info: <sip:64.125.111.10>;method="NOTIFY;Event=telephone-event;Duration=1000"
Content-Length: 0
26-Jan-2013 20:08:21.979 L:2.1[Line:10000<<+18009806858] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=264bc37cb65a3a14
[email protected]:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-264bc37cb65a3a14-1---d8754z-;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Content-Type: application/sdp
Supported: replaces
Content-Length: 298
v=0
o=3cxPS 411058569216 200974270466 IN IP4 72.94.24.236
s=3cxPS Audio call
c=IN IP4 72.94.24.236
t=0 0
m=image 9004 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:10500
a=T38FaxMa
atagram:1500
a=T38FaxUdpEC:t38UDPRedundancy
26-Jan-2013 20:08:21.979 SendMsg from <sip:
26-Jan-2013 20:08:21.664 L:2.1[Line:10000<<+18009806858] Sending: OnSendResp Send 200/INVITE from 0.0.0.0:0 tid=0a1f.37525c76.0
[email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 209.216.15.70;branch=z9hG4bK0a1f.37525c76.0
Via: SIP/2.0/UDP 64.125.111.10:5060;branch=z9hG4bK9a0c62b47684de9209d749ac80484910
Record-Route: <sip:209.216.15.70;lr=on;ftag=3568237698-887444>
Contact: <sip:
To: <sip:
Call-ID:
[email protected]
CSeq: 1 INVITE
Supported: replaces
User-Agent: 3CXPhoneSystem 11.0.28392.820 (27565)
Content-Length: 224
v=0
o=3cxPS 411058569216 200974270465 IN IP4 72.94.24.236
s=3cxPS Audio call
t=0 0
m=audio 9002 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
