DidForSale setttings
Discussion in '3CX Phone System - General' started by Gevorg, Oct 7, 2010.
  1. Gevorg
    Oct 7, 2010
    I am using DidForSale.com as a DID provider. Unfortunatelly there is no template for them.
    I can recive inbound calls fine, but outbound calls end up with message
    403 Forbidden, we do not trust you for sip:xxxxxxxxx@ip:5060
    Not sure what do they want.
    thanks.
    10,582
    249
    Does 3CX show that the trunk is registered? Are you sure that you are sending the correct digits to them? Have you spoken to them for any help that they can offer?
  3. Gevorg
    Oct 7, 2010
    they do not require registration.
    They go by my static IP.
    I suspect that theres something i am missing in Outbound parameters.
  4. Gevorg
    Oct 7, 2010
    Works now :)
    turned out they must enable dialing out feature by IP address... Their support just did it.
  5. it35
    May 13, 2010
    Incoming Trunk DidForSale setttings
    1ADD VOIP Provider Wizard
    2GENERIC SIP TRUNK -> NAME SIP DIDFORSALE
    3ADD VOIP PROVIDER WIZARD
    SIP SERVER HOSTANAME OR IP ->YOUR 3CX IP
    SIP SERVER PORT-> 5060
    OUTBOUND PROXY HOSTNAME OR IP->YOUR DID PROVIDERS IP
    OUTBOUND PROXY PORT PORT->5060
    EXTERNAL NUMBER ->YOUR DID NUMBER 14533.....
    AUTHENDICATION ID->YOUR EMAIL ADDRESS THAT YOU ARE USING TO LOG ON TO DIDFORSALE
    PASSWORD->YOUR LOGIN PASSWORD
    MAX SIMUT CALLS ->4 (WHAT EVER LICENCE U HAVE)
    DID/DDI NAME->YOUR DID NUMBER" 14256361914"
    DID/DID NUMBER/MASK->YOUR DID NUMBER AGAIN
    AVAILABLE PORTS ->WHAT EVER IS THERE
    OFFICE HOURS->CONNECT TO EXTENTION -> CHOOSE AN EXTENTION WHICH YOU HAVE CREATED PRIOR TO THAT.
    http://WWW.IT-SOLUTIONSUSA.COM
    IOANNIS KONSTAS
