didlogic
Discussion in '3CX Phone System - General' started by seanc, Sep 9, 2015.
  1. seanc
    May 25, 2015
    25
    Hello everyone!
    I wonder if anyone used didlogic before??
    i have bought a couple of local uk numbers from didlogic, i have set one up with a SIP trunk.
    does each seperate number i have bought need forwarding to a NEW SIP trunk? is that the way to do things? or should i forward it to the exisiting SIP trunk - would that work for showing caller ID ?
    i think each number on a SIP trunk is the way to go so i can seperate and control with call rules?
