Diference WinClient Q-Manager and Switchboard Queue Calls
Discussion in '3CX Phone System - General' started by Tomas Raska, Dec 6, 2017.
  1. Tomas Raska
    Aug 18, 2017
    58
    6
    In Web Client, in Switchboard / Queue Calls i see incomming and answered ongoing Calls, in Windows Client only Incoming Calls, when Call somebody answer and talk, then this Call from this liste disappear.
    Is this OK?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    360
    Hello @Tomas Raska
    You should be able to see ongoing calls in the Windows client as well. Open the Switchboard and click on the settings icon. Make sure that the appropriate setting is enabled.
  3. Tomas Raska
    Aug 18, 2017
    58
    6
    I have everything checked, but in Q-manager Window I see only waiting calls in queue, not connected calls
  4. Tomas Raska
    Aug 18, 2017
    58
    6
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    Once a Queue Call is answered, in a way it "leaves" the Queue and is handed directly to the Extension that answered it. This means that you should check the Group Rights of the extension so that you (the monitorer) have the "Can see group calls" right and that the agents (who you are monitoring) have the "Show calls to group members" right. Of course you must also make sure that your and their extensions are in the same Extension Group.
  6. Tomas Raska
    Aug 18, 2017
    58
    6
    I am in Call Queue defined as Queue manager, but I am not in same Group as people in queue.
    And in Webclient I see connected ongoing calls and in Winclient not. This is interesting.
    If I am in same Group, then work too Winclient.
  7. NickD_3CX
    Jun 2, 2014
    1,283
    68
    To actually see the calls of users, you must be in the same Extension Group as the users. Remember, you can be in multiple groups at once having different group rights in each group, so you situation sounds like you need this.
    Add your extension to also be in the group where the agents are, enable the rights as mentioned, and depending on whether you want to see your calls, adjust the "Show calls to group members" right of your extension accordingly.
