diff ringtone for trunk/group?
Discussion in '3CX Phone System - General' started by ZenMasta, Dec 14, 2011.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    Is it possible to set a different ring tone depending on the trunk or ring group?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    I don't think so currently, except supported by phone itself.
    Regards
  3. efounco
    efounco New Member
    Sep 28, 2011
    148
    You can setup multiple extensions on the phone with different ringtones for each. Then, forward calls from trunk 'a' to extension 1 and trunk 'b' to extension 2, etc.
