Different behavior for internal calls (never go to voicemail)
Discussion in 'Ideas' started by jackkirby, Oct 3, 2016.
  1. jackkirby
    Sep 30, 2016
    in the extension, under forwarding rulles- there is a section where there is different behavior for internal calls. There is not an option where internal calls never go to voice mail. This option would be good because if want to transfer a call over internally, you will not have to worry about it going to voicemail or if you want to call them.
    This feature would be a good idea.
