Different designs for different accounts?
Discussion in 'Windows' started by Peter2_1, May 23, 2017.
  1. Peter2_1
    Dec 15, 2016
    11
    I have different accounts on my client, and for an easy and clear display which account is active I want to set something like this:
    • For account A use red background and green fonts
    • For account B use yellow background and blue fonts
    • For account C use black background and white fonts
    Is it possible to set this?
    Peter
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Peter2_1,
    There are currently 4 different themes on the client that can be changed from Settings > Themes. You can also set a custom picture as a background. I'm afraid that you cannot select the colors yourself. However you can post this to the forum's Ideas section (https://www.3cx.com/community/forums/3cx-ideas.57/), for the appropriate department to consider.
  3. Peter2_1
    Dec 15, 2016
    11
    Hi @panayiotis_3CX
    thanks, but the problem is - this settings are independent from my account. I can select a theme and a background - and this will be fixed until I change it for myself.
    I need a "change of account changes the design"
