Different ring scheme on depending on incoming line
Discussion in '3CX Phone System - General' started by Urbok, Sep 21, 2007.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    It's possible to define a different ring sound depending on the incoming line?
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    No. To the best of my knowledge 3CX does not control ring patterns. Patterns would be defined at the answering device. I believe, maybe wrongly, that some multiple line IP phones can have different ring patterns assigned to different lines, but can't think of any other way. I use PAP2s myself and ring pattern is defined in the actual device.
  3. zakfleming
    Aug 17, 2007
    48
    Do you mean ring tones? Yes possibly on some SIP phones & some softphones.
  4. Anonymous
    Anonymous Guest
    Ring pattern, is defined by the ATA.
    Some phones might have that functionality aswell, but by default it is the ATA atm.
