Different Ring tone
Discussion in '3CX Phone System - General' started by Brice, Oct 24, 2011.
  1. Brice
    Mar 23, 2009
    I would like to know if is possible with 3CX and Thomson ST2030 to do with different ring tone depending on the number called. For example an outsider called 0123456789 it sounds one way, if someone calls it sounds different ... 0123456788
    Thank you!
  2. Gabriele
    Oct 12, 2011
    13
    With 3CX you can't. You have to set it directly on the phone.
    For example yealink can do it.
