Different Ringtones for External Calls?
Discussion in '3CX Phone System - General' started by TSlocum, Jan 17, 2014.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    We just rolled out our Cisco SPA514G Voip phones and I've got a question regarding ringtones. It seems that when a call comes in, the ringtone is different than internal phone-to-phone calls. Is this right? How can I specify which tone gets played for different events?
  2. mlump
    mlump New Member
    Feb 24, 2012
    113
    What make of phones did you deploy? This is specified in the provisioning template, the feature you are referring to is called Distinctive ringing. If you reply with what phones you have i should be able to point out the settings in the template file.
  3. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Sorry, I knew I was forgetting to mention something. We've got Cisco SPA514g's.
  4. mlump
    mlump New Member
    Feb 24, 2012
    113
    Ok so in the provisioning template these are the settings responsible for Distinctive Ringing:
    <!--### Distinctive ringing ###-->
    <!--# Setting for distinctive ringing base on altert info -->
    <!--# info=external call from external line (no reformatting has been applied)-->
    <!--# info=international call from external line, reformatting detected international call-->
    <!--# info=national call from external line, reformatting detected national call-->
    <!--# info=local call from external line, reformatting detected local call-->
    <!--# info=queue call from queue-->
    <!--# info=ivr call from IVR-->
    <Ring1 group="Phone/Ring_Tone">n=Classic-1;w=3;c=1</Ring1>
    <Ring2 group="Phone/Ring_Tone">h=external;w=3;c=2</Ring2>
    <Ring3 group="Phone/Ring_Tone">h=international;w=3;c=3</Ring3>
    <Ring4 group="Phone/Ring_Tone">h=national;w=3;c=4</Ring4>
    <Ring5 group="Phone/Ring_Tone">h=local;w=2;c=1</Ring5>
    <Ring6 group="Phone/Ring_Tone">h=queue;w=2;c=2</Ring6>
    <Ring7 group="Phone/Ring_Tone">h=ivr;w=2;c=3</Ring7>
    <Ring8 group="Phone/Ring_Tone">n=Simple-4;w=2;c=4</Ring8>
    <Ring9 group="Phone/Ring_Tone">n=Simple-5;w=2;c=5</Ring9>
    <Ring10 group="Phone/Ring_Tone">n=Office;w=4;c=1</Ring10>
    If you want to disable distinctive ringing and allow users to control there ringtones normally you will need to change the settings in the template to these and re-provision the phones.
    <Ring2 group="Phone/Ring_Tone">n=Classic-2;w=3;c=2</Ring2>
    <Ring3 group="Phone/Ring_Tone">n=Classic-3;w=3;c=3</Ring3>
    <Ring4 group="Phone/Ring_Tone">n=Classic-4;w=3;c=4</Ring4>
    <Ring5 group="Phone/Ring_Tone">n=Simple-1;w=2;c=1</Ring5>
    <Ring6 group="Phone/Ring_Tone">n=Simple-2;w=2;c=2</Ring6>
    <Ring7 group="Phone/Ring_Tone">n=Simple-3;w=2;c=3</Ring7>
    <Ring11 group="Phone/Ring_Tone">n=Pulse;w=5;c=1</Ring11>
    <Ring12 group="Phone/Ring_Tone">n=Du-dut;w=6;c=1</Ring12>
  5. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    What do I need to change? The two things you posted are exactly the same. Also you typo'd 'alert' in the first line. ;)
  6. mlump
    mlump New Member
    Feb 24, 2012
    113
    I just edited my previous post with the corrected info. That first line is commented out and copied directly from the 3CX template i didn't even notice the typo lol, anyway it does not have any affect on the phone.
  7. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    So when I do this, every call will have the ringtone selected on the phone itself?
  8. mlump
    mlump New Member
    Feb 24, 2012
    113
    Correct
  9. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Excellent. Thank you.
  10. mlump
    mlump New Member
    Feb 24, 2012
    113
    No problem, I actually just helped a partner of mine with the same problem not to long ago.
  11. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Two more related questions:
    Without changing anything, the provisioning template has all "n=[tone]" rather than some with an 'h'. It still rings differently for incoming external calls and interoffice calls. Why is that?
    Second, how can I change the incoming external call tone? For example, change it to "Simple-4"?
  12. mlump
    mlump New Member
    Feb 24, 2012
    113
    Unfortunately I don't have the answer to your follow up questions. I haven't worked with the Cisco phones that much and the one time I did I went just far enough on how to successfully remove the distinctive Ringing. I did not look into actually making changes to the tones or anything.
  13. mlump
    mlump New Member
    Feb 24, 2012
    113
    If you had Yealink phones i could be of more help.
