Differentiating Calls
Discussion in '3CX Phone System - General' started by Kenny Nawotniak, Jul 19, 2017.
  1. Kenny Nawotniak
    Jun 26, 2017
    I have a 3CX Phone System on a Windows 7 PC. We have both Cisco SPA Phones and Yealink T29G phones on it, we were wondering how to set up the system so that users know if the call is being transferred to them from another user or if the call was directly for them. Thanks for the help!
  2. AGidi
    Jun 30, 2017
    31
    hmm we have yealinks T38 and the CID displays from:DID on screen.
    If its from the IVR it will show somethink like group800:CID
    if its from an inbound line directly, CID:DID shows on the tel display.
    Wha do you get?
  3. Kenny Nawotniak
    Jun 26, 2017
    Ours will display the CID followed by a blastgroup if the call was made to one. Otherwise it only displays the Caller ID.
  4. AGidi
    Jun 30, 2017
    31
    Then im confused about the issue. Im sorry.
    If its being transfered by a previous user, it should be an attended transfer ?
    if its direct DID to ext, they get the CID on display. right?
  5. Kenny Nawotniak
    Jun 26, 2017
    There aren't any DID's setup for this system yet besides the main number. When someone calls the main number, the call hits a blast group. The users would like to be able to know if the call is either directed to the blast group, to their particular extension, or being transferred from a different extension.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,388
    279
    When a call comes through a blast group the blast group will appear on the screen of the phone. But if the call comes from a different extension then the name of the blast group will not appear on the screen. What you will see on the screen however depends on the type of transfer.
    When the call is transferred through a blind transfer then you will not see who is transferring the call only the number of the caller. When it is an attended transfer then you will see the extension that will perform the transfer calling you and when the transfer is complete then you will see the callers number.
