Digital Feedback on callers voice
Discussion in 'Windows' started by jason.frew, Dec 10, 2009.
  1. jason.frew
    Dec 7, 2009
    I am Experiencing an issue with our 3cx system.
    From time to time the connected call will be interrupted with a beep, and from that point in the call we experience digital feedback on the callers voice. It sounds like the persons voice has changed form a natural speaking voice to a robotic voice. is stays like that until the end of the call.
    When you hang up and recieve another call the issue has cleared.
    Any thoughts?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    You need to describe the interfaces and circuit types you are using.
