Digital Recepcionist Skipped
Discussion in '3CX Phone System - General' started by boden, Feb 10, 2008.
  1. boden
    Nov 27, 2007
    16
    Hi! I am having the following problem.
    First time I call my system from outside I hear the digital recepcionist without problems.
    But for example if I call again from the same number, I do not get the digital recepcionist. I get the action I normally get AFTER the digital recepcionist. Any ideas?
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your post.
    Can you please clarify what you mean by 'get the action I normally get AFTER the digital recepcionist' ?
  3. boden
    Nov 27, 2007
    16
    It fowards the call to a group in business hours, or to an voice mail box outside business hours.
  4. William400
    Aug 21, 2006
    1,005
    Will the first call to the DR still be in progress when you try the 2nd call?
    Are the inbound calls coming in via a VOIP Provider or via a Gateway? Please give details.
    Are you able to repro the issue, with 1 inbound call to DR and a 2nd internal call to the DR?
