Digital Reception / Call Group Problem
Discussion in '3CX Phone System - General' started by zakfleming, Sep 8, 2007.
  1. zakfleming
    Aug 17, 2007
    48
    I am playing with 3CX before i install it, i have setup a digital reception and i have set that up so it will ring a call group. I have set it if nobody answers the call ends. But when nobody answers it says transfer fails and goes through the digital reception again. How do i fix this?
    Also when there is no answer on a extension number it says transfer failed and it takes it to the digital reception is this to do with it?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please enable the log level to "Verbose (only used for debugging purposes)". Restart all 3cx services or restart 3cx box. Do the same steps again for log the problem at console status log. Then post the console log here for us to investigate your problem.
  3. zakfleming
    Aug 17, 2007
    48
    sorry for my ignorance were is the logs please? I have changed the settings.
  4. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Unless I am mistaken, right after you have duplicated the error, go to Admin page, left column > Phone System > Server Status, copy & paste relevant portion.
  5. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    RE: Ring Group
    Hi if I am not wrong you are talking of ring grop/call hunt. if this is the case there is a Destination if no answer >>> option under the ring group setting where you can specify what you want to be done if no calls are answered. I hope this will help you solve your problem....
  6. zakfleming
    Aug 17, 2007
    48
    it doesnt realy matter now i have decided to forward it onto a voice mail, thanks anyway
  7. wisecomputers
    wisecomputers New Member
    Apr 24, 2008
    126
    But it does matter to us. It works great until there are no phones registerd in the group. If no one is registerd then it fails. Any ideas would be great.
    Dan
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Thank you for report. This bug is just fixed.
  9. wisecomputers
    Apr 24, 2008
    126
    thank you. You always great. I wish all software companies where like you guys.
  10. wisecomputers
    Apr 24, 2008
    126
