Digital Receptionist comes in on an already connected call.
Discussion in '3CX Phone System - General' started by robhazes, Mar 17, 2011.
  1. robhazes
    Apr 22, 2009
    24
    I have a problem with the digital receptionist. I use it in a menu where incoming callers can transfer themselves to an internal line.
    Sometimes, while in a call with an incoming caller, we experience that the digital receptionist suddenly cuts in, and repeats the menu message, thus making it impossible to continue the conversation. The call is not lost, both sides can hear each other, it is just that the digital receptionist gets mixed into the call.
    Any solutions?
    Am using the latest version with all the service packs up to date.
    11,095
    327
    Re: Digital Receptionist comes in on an already connected ca
    The 3CX server log may give some information as to what is happening.
  3. robhazes
    Apr 22, 2009
    24
    Thanks. Have now switched on verbose logging and logging to disk. Will have to wait for the next occurrence and will let you know.
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Did you get this sorted?
  5. robhazes
    Apr 22, 2009
    24
    Sorry, no. Actually I am still logging, but it has not happened again since I started the logger... Will post results when I catch it.
  6. davidbenwell
    Apr 27, 2010
    704
    thanks for the update, We will continue to monitor this thread and reply when required.
  7. robhazes
    Apr 22, 2009
    24
    Bingo! It happened once today, and I have lots of log data. Some of the log files are more than 10 MB, so I will need some help. What should I look for, and in which log files?
  8. leejor
    11,095
    327
    In the server logs, you will have to eliminate (if you want to post it here) all but the time frame of the occurrence , start to finish.
  9. robhazes
    Apr 22, 2009
    24
    Sorry, can't do that. I extracted the relevant lines for a 2 minute period from 3cxivrserver.log, 3cxivrservertrace.log and 3cxphonesystem.log. Together aprox. 2000 lines with text. Besides that the size would be a problem in a forum like this, I might oversee details which should not be published, like passwords. I would prefer to send this by email to someone who is interested in solving the problem. Later the filtered details could be published.
  10. davidbenwell
    Apr 27, 2010
    704
    Hi, submit a support ticket http://www.it-communicationsltd.co.uk/support/index.php?a=add
    include your logs with the ticket.
  11. robhazes
    Apr 22, 2009
    24
    Done, thanks!
  12. davidbenwell
    Apr 27, 2010
    704
    Hi, we have had a look at the logs, this appears to be a IVR Session Issue, advise you to restart the Abyss Web Server as outline in my response to the support ticket.
    Please let us know if you continue to get this issue.
  13. robhazes
    Apr 22, 2009
    24
    I did the Abyss Web Server reset as requested some days ago.
    I had a new occurrence today at approx. 10:50. This time I know exactly which call. It happened on an incoming call and we called back afterwards.
    I have all the logs for those who want to have a look at them.
  14. davidbenwell
    Apr 27, 2010
    704
    posted a reply to the support ticket,
    You appear to have MP3 file listed bakerman2.mp3
    this is no longer supported and shoud be a .wav file
    could you remove this and replace with a .wav file and let me know how you get on?
  15. robhazes
    Apr 22, 2009
    24
    I have now updated the 3CX system from version 9 to version 10, SP1, and I have replaced the mp3 file with the required wav file.
    I will post here if I run in a new occurrence.
