Digital Receptionist do not connecting to extension
Discussion in '3CX Phone System - General' started by ngsolutions, Apr 24, 2007.
  1. ngsolutions
    Dec 28, 2006
    8
    HI every one
    I have problem with Digital Receptionist. J have configurated option time out 5 and connect to extension. After prompt the line is deaf.
    Do you have any idea to fix it??
  2. Alexander
    Nov 10, 2006
    73
    Hi !
    Please repeat the sutuation and then send your log-files (from the '<3CX PhoneSystem folder>\Data\Logs' folder) to me. You can have a look at them also (especially at the '3CXIvr*.log' files), probably you will see the reason of the problem.
    Thanks for your help :)
