Digital Receptionist does not answer call
Discussion in '3CX Phone System - General' started by esoteric56, Jan 12, 2010.
  1. esoteric56
    Jan 12, 2010
    I have set up a Digital Receptionist with a recorded Prompt.
    If I use an IP Phone to call the Digital Receptionist it works just fine and I can hear the recorded prompt.
    For voice calls originating from the TDM ( We use a Dialogic gateway) the call gets disconnected when calling the Digital receptionist , however works fine to other extensions.
    As a work around I created an Extension and set the forwarding rule so that When the extension is not registered calls are forwarded to the Digital receptionist.
    This approach works fine when I call the Dummy extension and I can hear the prompt from my TDM Phone.
    Can anybody help explain this behavior, Also how can I make the Digital receptionist work over TDM without using the dummy extension.
