Digital Receptionist Hangsup After 10 Seconds.....
Discussion in '3CX Phone System - General' started by chrisjr, Apr 30, 2007.
  1. chrisjr
    Jan 23, 2007
    21
    I'm using Broadvoice and I'm able to make inbound and outbound calls without having any problems. But I'm having problems when I use a digital receptionist. Every time I use one it will answer the call for me but then hangs up 10-15 seconds later. If I do press 1 or 2 it will ring the ring group but still disconnect after 10-15 seconds (10-15 seconds after digital receptionist picks up). I've pasted my server log below as well. Does anyone have any suggestions??
    11:25:22.343 StratLink::eek:nHangUp Call(C:6): Ln:10000@Broadovice1 hung up call; reason: BYE
    11:25:15.765 CallLegImpl::eek:nConnected Call(C:6): Created audio channel for Ext.101 (192.168.2.4:5004) with Media Server (192.168.2.6:7018)
    11:25:15.765 StratInOut::eek:nConnected Call(C:6): Setup completed for call from Ln:10000@Broadovice1 to Ext.101
    11:25:15.093 CallConf::eek:nProvisional Call(C:6): got response from 101
    11:25:09.796 MediaServerReporting::DTMFhandler from 'PhoneServer:0/MediaServer':DTMF (RTP) from 147.135.20.250:14042 arrived. in-band DTMF tone detection is turned off.
    11:25:05.687 CallLegImpl::eek:nConnected Call(C:6): Created audio channel for Ln:10000@Broadovice1 (147.135.20.250:14042) with Media Server (67.53.129.195:9000)
    11:25:05.671 CallConf::eek:nIncoming Call(C:6): Incoming call from Ln:10000@Broadovice1 to sip:2627371044@192.168.2.6
