Digital Receptionist-how to change external number on set days
Discussion in '3CX Phone System - General' started by davidbr117, Apr 12, 2018.
  1. davidbr117
    Apr 12, 2018
    Hi wondering if anyone can help me
    ATM I have a digital receptinist set to out of hours, so when someone calls out off hours, they get a voice prompt and press option 1, then it connects to a dummy exstension whitch is forwarded to my mobile
    my question is,is it possible for example
    if they press option 1 on these days
    monday-friday have it ring my number, then
    saturday-sunday have it ring someone elses mobile
    at the moment i am having to change it manually, is there away to make it automatic
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,997
    190
    Maybe thru the CFD (Call Flow Designer) ?
    Seems logical this would be easy to do -
    M-F - ext 500
    S-S - ext 501
    based on time of day...
  3. davidbr117
    Apr 12, 2018
    Thanks ill have a look into that now
  4. craigreilly
    Feb 1, 2012
    2,997
    190
    And by using an extension… You can easily change the mobile number associated with that extension, instead of having to re-create the CFD
  5. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    939
    149
    #5 Saqqara, Apr 12, 2018
