Digital Receptionist issue after upgrade to 15.5
jensen
After upgrading from 14.0 to 15.5, the Digital Receptionist does not work, and when I try to edit existing or new extensions, I get:
Could not find a part of the path 'C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts\Sets\38ec17be-817e-44f3-8bb5-84d0f5394eaf\SetInfo.xml'.
The folder with the guid name did not exist, so I copied the existing folder and named it to match; however, I get the same error message.
How do I correct this?
Please try next:
After creating and rename the folder name, copy a “SetInfo.xml” file from a not used folder into the new folder and several *.wav files.
Then go to Settings – System Prompts – Manage Prompt Sets and delete the created prompt set or all prompt sets.
Reset the services and download the proper prompt set(s)
Hope this will help.
Please try next:
Thanks,
Actually, after copying everything into the folder that 3cx was looking for, I just restarted the services and now it works fine.
Thanks,
Except...
When calling an extension that does not answer, there is about 15 seconds of white noise between the time the hold music stops and the voicemail prompt plays. What is causing that? Both the hold music and the prompt play properly when played back.
Get 3CX - Absolutely Free!
3CX
