Digital Receptionist - keystroke delay between layers
Discussion in '3CX Phone System - General' started by barrym, Jan 7, 2011.
  1. barrym
    Jun 7, 2010
    I have set up a hierarchy of Digital Receptionists : a top layer - press 1 for sales, 2 for support etc and sublayers below them. eg a sales receptionist press 1 for products, 2 for services, etc. and a third layer under services press 1 for serviceA, 2 for serviceB etc.
    There appears to be a delay before the keystrokes can be entered. quickly pressing 211 at the top level does not direct the user to the serviceA receptionist. If I wait 3 secs between each keystroke, it works.
    The reason I would like to be able to quickly key in 211 is because our previous phone system used ext's 201 thru 230. We now use 2 for the support digital receptionist. but existing customers are not waiting to hear the message that we have changed our menu system and need to press 7 followed by the ext number ( ext 201 is now ext 7201) so I would like to capture 201 and route it to 7201. I can do this via the digital receptionist by setting the 3rd layer down to ring 7201 if 1 is pressed but only if I delay 2-3 secs between each keystroke. Any way to remove this delay?
    Thank you for a great piece of software.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    It makes sense to me. If it allowed for immediate key passing then you would never be able to enter a full extension at the beginning of the message (direct extension that is).
