Digital receptionist multiple did`s
Discussion in '3CX Phone System - General' started by vand, Jul 24, 2014.
  1. vand
    Oct 18, 2013
    8
    Hi all
    I have problem with setting up digital receptionist. I got one sip trunk with multiple numbers, I assign to each did different message, however when I call to any of my did it always play the first message.
    So I have main number which is assign to the SIP but is look like it override the settings for dids, if that make any sense...
    Please advise
  2. jasit
    jasit New Member
    Feb 12, 2013
    172
    Did you check off the Source identification by DID and add the did's to the list. It should create new inbound routes for you for each of the DID's
  3. vand
    Oct 18, 2013
    8
    Thanks for reply.
    Yes, I tried disable/enable Source identification by DID doesn't change anything. I have already all rules for each rule different digital receptionist... but its not working :roll:
    I think I need to set inbound parameters, does anyone know which sip field should be altered?
