Digital receptionist not working
Discussion in '3CX Phone System - General' started by flexmcpee, Oct 22, 2010.
  1. flexmcpee
    Oct 19, 2010
    7
    I have setup 3cx so far succesfully for testing. I have setup a digital receptionist and provided a recording using the audio format required. When I call the DR (IVR) ext 800 it rings for 1 second then cuts the call after 2 seconds and doesnt play the recording similarly if I dont provide an audio file it does the same thing? When I check the system extension status the IVR extension 800 turns Yellow only for 2 seconds then back to Green for idle
    I have not setup our pstn gatway or anything like that I just want to test interanlly most of the functionality i.e the Digital receptionist for one.
    Am i doing something wrong or do I need to do something else. Similarly the same behaviour occurs when I try to leave a Voice Mail for an extenion.
    Please help everything else seems to be working well so far.
    Alex
  2. flexmcpee
    Oct 19, 2010
    7
    Here is the log that may help?
    17:05:50.304 [CM503008]: Call(89): Call is terminated
    17:05:47.584 [CM503007]: Call(89): Device joined: sip:800@127.0.0.1:40600;rinstance=1c0506fa5de8c8e3
    17:05:47.568 [CM503007]: Call(89): Device joined: sip:201@192.168.0.125:5060;transport=udp
    17:05:47.568 [CM505001]: Ext.800: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:800@127.0.0.1:5060]
    17:05:47.568 [CM503002]: Call(89): Alerting sip:800@127.0.0.1:40600;rinstance=1c0506fa5de8c8e3
    17:05:47.412 [CM503025]: Call(89): Calling Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=1c0506fa5de8c8e3]
    17:05:47.365 [CM503004]: Call(89): Route 1: Ext:Ext.800@[Dev:sip:800@127.0.0.1:40600;rinstance=1c0506fa5de8c8e3]
    17:05:47.365 [CM503010]: Making route(s) to "800"<sip:800@192.168.0.9:5060>
    17:05:47.365 [CM505001]: Ext.201: Device info: Device Identified: [Man: Aastra;Mod: 5x series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, recvonly] UserAgent: [Aastra 53i/2.6.0.1008] PBX contact: [sip:201@192.168.0.9:5060]
    17:05:47.349 [CM503001]: Call(89): Incoming call from Ext.201 to "800"<sip:800@192.168.0.9:5060>
  3. TotallyVoIP
    Jul 2, 2010
    77
    Just to rule out the obvious stuff can you post a screen shot of your DR settings page?
  4. flexmcpee
    Oct 19, 2010
    7
    Hi Richard,
    Thanks for your reply please see the screenshot attached.
    Alex
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Try loading another audio file and see what happens. It is possible that your current audio file is corrupted or incomplete.
    If you used one of those free audio converter programs.
  6. flexmcpee
    Oct 19, 2010
    7
    I figured it out.
    In these steps:
    Reinstalled 3cx
    Updated all updates for 3cx
    Installed all IIS 7 features using add role features in server 2008r2
    IVR basic settings connect as "administrator" and our password to have access to the 3cx directory
    Checked .vxml was available in MIME Types.
    This link helped is suspecting somethings was wrong with IIS http://www.3cx.com/blog/docs/troubleshooting-iis-ivr/
    All working spot on :)
