Digital Receptionist...Please wait...and a blast of on hold
Discussion in '3CX Phone System - General' started by AvanteICT, Jan 10, 2013.
  1. AvanteICT
    Oct 22, 2012
    6
    Hi 3cx ers
    So I've set up my digital receptionist....the action for press 1 is to point to an extension that is set to dial an external number...
    The trouble is.....after pressing 1 I get the system message saying 'please hold while I transfer your call'.....a quick blast of our on hold music then the call goes through...
    Is there any way to stop the system message and the blast of hold music? It just comes across a bit clunky...
    In a way it's similar to what making a call from the 3CX myphone does when making an external call from my phone book... with the blast of on hold music that is.
  2. AvanteICT
    Oct 22, 2012
    6
    Re: Digital Receptionist...Please wait...and a blast of on h
    3cx 11 SP2 if that helps with any suggestions...
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    You can replace default on hold music with some ring tone?
  4. AvanteICT
    Oct 22, 2012
    6
    Thanks mixig, we'd thought of that but we'd like on hold music for when people are on hold not when using the digital receptionist function...I think it's going to be one of those things we have to live with for the time being...
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Just as mixig had suggested that you could replace using a ring tone, you can also do using a music file of your choice. There are a number of websites that have royalty free music files where for a small fee you obtain the rights to use.
