Digital Receptionist Prompt Browse Error
Discussion in '3CX Phone System - General' started by integrax, Feb 15, 2010.
  1. integrax
    Dec 9, 2008
    19
    Hello...
    I use W2K3 SR-2 with IE 8 on a dual Xeon Proliant HP server with some other internet applications running on IIS and install 3CX ver 8 on it, and almost everything works fine, but when I try to upload audio files por personalized prompts on Digital receptionist General configuratin screen, when I click BROWSE, I get this pop-up error:
    Internet Explorer Script Error, An Error has occurred in the script on this page, Line: 13, Char:16, Error: Expected"/", Code:0 and a URL pointing to Forms.OpenFileDialog.htm.wgx
    If I uninstall and install on Cassini, it works great, but IVR stop answering calls very often, and I have to restart service.
    I prefer a solution using IIS, any ideas?
    Thank you
