Digital Receptionist Recording - Any phone
Discussion in '3CX Phone System - General' started by jjbuckingham, Jan 4, 2012.
  1. jjbuckingham
    May 13, 2010
    6
    Does anyone know why you can't record a digital receptionist from any phone (outside phone)? I can enter a 7 digit number and it will call my cell, but there is no audio. If I call my extension, it works fine. I am running version 10, SP5.
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Why would you do this?
    Its designed to be recorded only from a registered pbx extension as it says in field description.
