Digital Receptionist Repeating with input
Discussion in '3CX Phone System - General' started by SPMatt, Apr 24, 2017.
  1. SPMatt
    Apr 24, 2017
    My 3CX v15 setup has incoming calls going into a DR that can allow transfers to a department, or a "Dial extension" option. Whenever someone dials any extension the system repeats the DR prompt over and over until we set it up to send the call to the receptionist after a timeout of 1 second.
    How can I get dial by extension working again?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    First, dial the DR extension directly from an internal extension and see if you can get where needed. It may be a DTMF issue.
