Digital Receptionist timeout not working
Discussion in '3CX Phone System - General' started by CIA, Jan 25, 2012.
  1. CIA
    CIA
    Jan 25, 2012
    I have 3cx v10 sp5, the digital receptionist timeout option is not working, it simply drop the call after some time.
    I have specified that after 45 second it should forward the call to an extension, regardless the option and the timeout i choose it always drop the call after some time.
    It only works if i choose the empty.wav in the options, if i put another wav it doesn't work.
    Some advice?
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    You have to wait until the prompt finish for Timeout to be triggered. This option is working. What wav do you use? Do you see something in logs?
