Digital Receptionist to transfer to external number
Discussion in '3CX Phone System - General' started by bryanford, Sep 1, 2008.
  1. bryanford
    Sep 1, 2008
    8
    Hi all,
    I would like the option of, for example, "Press 9 to enter in an external number to dial".
    The user then presses 9 and enters in a number, then 3cx will ring that number and transfer the call.
    Reason for this is I am using 3cx so my dad can dial in from thailand at a cheap rate, and pretty much get access to an Australian phone line.
    Is this possible?
    Bryan
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Bryan,
    evrey thing you need Is possible with 3CX because simply it's the best
    any feature you need you can post feature request
    anyway by ata gateway like spa3102 your father can use your land line to make any call
  3. bryanford
    Sep 1, 2008
    8
    Thanks for your reply,
    Are you saying it is not a current feature but I can request it on the forums? Or is it possible already?
    THanks
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I was clear
    your father can use your land line to make any call if you have a pstn (FXO) gateway like linksys spa3102
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    I do not think so
    He Said 'Reason for this is I am using 3cx so my dad can dial in from thailand at a cheap rate, and pretty much get access to an Australian phone line.'
    his father use remote voip to dial pstn through 3CX
  6. bryanford
    Sep 1, 2008
    8
    Matt you are spot on.
    I bought a Thailand DID and mapped it to the 3cx server's Digital Receptionist in Australia.
    I want him to say, push 9, and enter in a number to dial out over VoIP.
    Bryan
  7. bryanford
    Sep 1, 2008
    8
    Hi matt,
    Yes, he is making calls from his mobile phone to a Thailand DID. He is always moving around so having a softphone isnt an option unfortunately :(
  8. amygoda
    amygoda Member
    Sep 18, 2006
    436
    try to forward the call to outside call by using outbound rule only
    ex: you want to dial 123 456 7890
    so you dial 9 123 456 7890
    so forward to outside number 9
    also see if http://www.freecall.com can help
