Digital Receptionist wouldnt transfer the call
Discussion in '3CX Phone System - General' started by Anonymous, Nov 30, 2006.
  1. Anonymous
    Anonymous Guest
    hi, thanks for this super easy phone system solution.
    i have just installed the latest build which is nov 28. when i call the digital receptionist, and press the desire button, it will loop playing the hold on music. the call is not transfered. when i check the other ext which should be transfered , there is no incoming call what so ever.
    thanksyou
  2. Anonymous
    Anonymous Guest
    sorry for the above post. i have read the answer and will wait for beta 4. thanks
