Digital Receptionist
Discussion in '3CX Phone System - General' started by smartel, Apr 27, 2017.
  1. smartel
    Nov 24, 2016
    8
    Good morning,
    Through the Digital Receptionist it´s possible enter a extension number? The option Call by name isn´t good for my case.
    My 3CX version is 15.0.
    11,113
    329
  3. smartel
    Nov 24, 2016
    8
    OK, I got it.
    And if I want disable this function. I´ts possible?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    There is an option but this will prevent the IVR to direct dial anything in the system and you will only be able to use the IVR options.
    log onto the 3CX Management console >> Settings >> Parameters>> Custom Parameters tab
    Search for
    IVR_DIRECT_DIALING_GRAMMAR and the default value for this should be [0-9]{3}
    Change the value to
    [0-9]{1}
    whatever number gets dialed by the Callers while they are on the ivr the number will get parsed as single digits. That means if they dial 101, the number will be split to 1,0,1 and checked against your ivr options. If option 1 is set then it will be followed for the caller, but they wont be able to direct dial any extension queues ring groups.
    GiannosC_3CX and JasonNadeau like this.
  5. smartel
    Nov 24, 2016
    8
    Thank you!
