Digital Receptionist_set up voice mail for the prompt
Discussion in 'CRM / Helpdesk / App Integration' started by Les Saland, Feb 7, 2017.
  1. Les Saland
    Feb 7, 2017
    My automated attendant has more than one prompt going to one extension.
    How do I set up a voice mail for the prompt and not the extension? i.e. sales is prompt 2 and admin is prompt 5 but both go to ext 102..
    The vmail message for prompt 2 should be different than the vmail message for prompt 5
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,617
    126
    Hi @Les Saland,
    You need to create 2 extensions for that, so you have 2 different voice mail boxes.
    Kind regards.
