Digital Receptionists/Queues not registering
Discussion in '3CX Phone System - General' started by freall, Jun 4, 2009.
  1. freall
    I have problems with inbound calls. My setup has been working OK for some time, but
    now 3CX terminates all inbound calls with:
    14:33:01.151 [CM503016]: Call(1): Target is not registered: Ext:Ext.950
    Extension 950 is a Queue.
    Findings:
    * Tried with digital receptionists and queues => Same result.
    * Restarted all services several times => Same result.
    * Upgraded to the last server version (v7.1.7139) => Same result.
    * Turned on verbose logging => Server never seems to register any of the extensions for both receptionists and queues.
    Anyone recognize this?
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    can you send your log file please.
