Digital Receptionists setup error
Discussion in '3CX Phone System - General' started by ecuellar, Jul 15, 2008.
  1. ecuellar
    Jul 15, 2008
    Hi, I just installed the system. Everything is working ok, but I have a problem with DR. Every time I call the DR, i just hear "error with an IVR session".
    It is a new setup, with a old PC, but with XP SP3 intalled from scratch.
    Please advice.
  2. ecuellar
    Jul 15, 2008
    Sorry guys, my mistake. I did change the apache port, and it seems it has to be 5481 always.
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    and DR is ok?
  4. ecuellar
    Jul 15, 2008
    yes DR is ok, and everything working great.
  5. francesco
    Jun 23, 2008
    102
    ok, good job with 3cx
