Digium cards compatible?
Discussion in '3CX Phone System - General' started by alew3, Dec 5, 2009.
  1. alew3
    Dec 5, 2009
    HI,
    I currently have an asterisk based system running Linux with this card installed for hookup to analogic phone lines http://www.digium.com/en/products/analog/aex800.php
    I´m considering migrating to a windows only system. I was wandering if 3CX is compatible with there Digium cards and if it will run under HyperV virtualized system.
    thanks,
    alessandro
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    What you could do is use the Asterisk system as a media gateway. Have the calls come into the Asterisk box via the Digium card and then trunk the calls to the 3CX box. That would be a pretty simple way of reusing your existing hardware although it does tie up a complete system just to use as a gateway, but if you are trying to not buy additional hardware right now, it is certainly an option.
