Dilemma on FXO / FXS
Discussion in '3CX Phone System - General' started by William400, Sep 18, 2006.
  1. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Hi All
    Can you please advise on the exact config a VOIP Gateway woudl need.
    So, if i have 6 analog lines from the telecoms box, what FXO / FXS configuration woudl i need to purchase?
    For simplicity lets say i will not need more lines from telecoms.
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    You need an FXO VoIP Gateway.
    An FXO device is a device that acts like a simple telephone, as opposed to an FXS device which acts like a telephone exchange (and supplies power).
    If you are planning to connect 6 analogue lines then you need to find a VoIP gateway that has 6 analog (FXO) ports or more. On the other hand the VoIP Gateway will also be connected to the network, and the lines reigstered with the SIP PBX.
    Furthermore our manual also describes the configuration of some common VoIP gateways under the 'Adding PSTN line(s) via a VOIP Gateway' chapter.
