Direct Access to Conference Bridge
Discussion in '3CX Phone System - General' started by GManNAtl, Nov 3, 2014.
  1. GManNAtl
    Sep 13, 2012
    58
    Am I missing something here? Is there no way to direct an incoming DID to the Conference Bridge? If not, why is there an option in this section of the admin to provide the external number. The bridge extension doesn't come up under extension, digitial receptionist, or any of the other categories.
  2. jasit
    jasit New Member
    Feb 12, 2013
    172
    You can setup the did to point to the 700/7000 extention, but the person calling the line will need to know the meeting passcode.
  3. GManNAtl
    Sep 13, 2012
    58
    That's my point, it doesn't show up in any of my lists. If I select "Connect to Extension", Connect to Que/Ring Group, Connect to Digital Receptionist, or Voicemail box for extension, 7000 doesn't show as an option in any of them.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    It may help to know which version of 3CX is being used and if a paid, demo or free one. I have a paid one and it (700 in my case)shows up under connect to extension.
  5. GManNAtl
    Sep 13, 2012
    58
    v12 128 call Enterprise, and this is the case on all off my paid installations, all v12.
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,375
    84
    I can't explain it either. As you can see in the screenshot below extension 700 is available. Just so that we haven't missed something, the DID registered and the Conference Extension you are trying to forward it to are on the same 3CX Phone System installation correct?
  7. GManNAtl
    Sep 13, 2012
    58
    Well, I temporarily fixed it using the VAD. However, it was bothering me so I went back to take a look.
    YMMV, but on my install it was at the very bottom of the extensions list. Not sorted by the extension number and it didn't say Conference Bridge or anything, it simply had 7000.
    Anyway, problem solved!
