Direct In Dial
Discussion in '3CX Documentation' started by markf100, Jun 14, 2017.
  1. markf100
    Jun 11, 2017
    15
    Documentation states that DID's can be setup via SIP trunking but there is no option for doing this.
    Also does this product have IVR capability?
    Thank you.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Hello @markf100
    If you setup a trunk next to the general tab there is a tab for you to add DID's. You can then direct these DID's via the inbound rules.
    There is also IVR capabilities built in the system.
    Please go the academy slides that explain most of the functions of the PBX and how they work
    https://www.3cx.com/3cxacademy/
    Also the admin manual contains a lot of crucial info regarding the operation of the system
    https://www.3cx.com/docs/manual/
  3. markf100
    Jun 11, 2017
    15
    Thanks Yiannis, got that sorted now moving onto the next problem.
