Direct SIP and Office Hours configuration?
Discussion in '3CX Phone System - General' started by pacpac, Jan 12, 2012.
  1. pacpac
    Jan 12, 2012
    58
    Hi, I am running the latest version of 3CX. How can I set up the Office Hours when calls are coming in via Direct SIP (calls are not routed via VoIP provider) to an Extension? I would like to have so calls are sent to a my recorded voicemail message between, let's say, 7pm and 7am. Inside office hours I need to have the calls sent to an IVR if no answer and if busy/unreachable.
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    I would set up an extension just for the purpose of taking the direct SIP calls. Then use forwarding rules to send the calls depending on office hours. Does that help?
  3. pacpac
    Jan 12, 2012
    58
    Yes, that helps, but how can I transfer to an IVR outside Office Hours set for that Extension, it looks like I can only transfer to generic voicemail prompt.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    go to extension status--->double click on extension--->Forwarding Rules--->out of office--->you will see options on how calls should be redirected outside of office hours. You can do that for each extension.
