Direct SIP not working
Discussion in 'Windows' started by darveesh, Jan 11, 2016.
  1. darveesh
    Jan 5, 2016
    Am trying to connect via Direct SIP using SJPhone SIP client. Looking at the 3CX activity log, the SIP INVITE gets to the 3CX system, but it's wanting an authentication? Here is the log entry:
    11-Jan-2016 08:49:33.532 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 10.1.243.84:5060 tid=0a01f3540000006e5693dd1e00004cf100000016 Call-ID=4097048036014CE7AFF8A6999D25A5B00x0a01f354:
    INVITE sip:1001@sip.gc.com SIP/2.0
    Via: SIP/2.0/UDP 10.1.243.84;branch=z9hG4bK0a01f3540000006e5693dd1e00004cf100000016;rport=5060
    Max-Forwards: 70
    Contact: <sip:10.1.243.84>
    To: <sip:1001@sip.gc.com>
    Call-ID: 4097048036014CE7AFF8A6999D25A5B00x0a01f354
    CSeq: 1 INVITE
    Content-Type: application/sdp
    Supported: replaces, norefersub, timer
    User-Agent: SJphone/1.65.377a (SJ Labs)
    Content-Length: 362
    v=0
    o=- 3661519773 3661519773 IN IP4 10.1.243.84
    s=SJphone
    c=IN IP4 10.1.243.84
    t=0 0
    m=audio 49164 RTP/AVP 3 97 98 8 0 101
    a=rtpmap:3 GSM/8000
    a=rtpmap:97 iLBC/8000
    a=rtpmap:98 iLBC/8000
    a=fmtp:98 mode=20
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-16
    a=setup:active
    a=sendrecv
    On the 3CX, I have simply created an extension (1001). No phone is registered or connected to that extension at this time. Under network setting -> FQDN, I have gc.com as the local SIP domain and I have checked the "Allow calls from/to external SIP URIs). I also have a DNS A record for sip.gc.com that points to the 3CX IP and a SRV record for gc.com that's pointing to the 3CX IP per http://www.3cx.com/blog/voip-howto/direct-sip/.
    Does anyone know why this is not working?
  2. darveesh
    Jan 5, 2016
    I also changed the Local SIP domain to sip.gc.com. Different error in the activity log file but still not working:
    11-Jan-2016 08:57:44.039 [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 10.1.243.84:5060 tid=0a01f3540000008c5693df080000344a00000020 Call-ID=9C23B84A7C7B427B8CBECA5E506AB9FD0x0a01f354:
    Via: SIP/2.0/UDP 10.1.243.84;branch=z9hG4bK0a01f3540000008c5693df080000344a00000020;rport=5060
    Max-Forwards: 70
    Call-ID: 9C23B84A7C7B427B8CBECA5E506AB9FD0x0a01f354
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="",realm="3CXPhoneSystem",nonce="414d535c0ca4700743:981e8c2a021eefb643400fd68d770542",uri="sip:1001@sip.gc.com",response="734df1ae36e720fa441d5969e9938ca3",algorithm=MD5
    Content-Length: 362
    v=0
    o=- 3661520264 3661520264 IN IP4 10.1.243.84
    s=SJphone
    t=0 0
    m=audio 49168 RTP/AVP 3 97 98 8 0 101
    a=rtpmap:3 GSM/8000
    a=fmtp:98 mode=20
    a=fmtp:101 0-16
    a=setup:active
    a=sendrecv
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
