Direct SIP Video Calls only get Audio
Discussion in '3CX Phone System - General' started by Ricardo Duarte, Oct 31, 2017.
  1. Ricardo Duarte
    Oct 31, 2017
    Hi there,
    I'm trying to call external video endpoints using Direct SIP.
    Internally I can do video calls both using internal extensions or direct sip addresses, but when I can external endpoints the call is audio-only.
    Firewall configuration is OK. Test shows everything as "done" and SIP alg is not detected.
    3CX is using a 1-to-1 NAT public IP and all ports are open.
    If I call the same endpoints without 3CX in the middle, the call shows video as it should, so I know both endpoints do have common codecs and inter-operate.
    Any idea what can be the problem?
    Thanks.
