Direct SIP
Discussion in '3CX Phone System - General' started by Techops, Feb 8, 2018.
Tags:
  1. Techops
    Feb 5, 2018
    30
    Been reading about the setting "3CX Phone System can make or receive Direct SIP Calls". (Console > Settings > Network > FQDN > Settings for Direct SIP Calls)
    Does anyone enable this option?
    If so, why?
    Read the 3CX blog post about how to enable it but not sure what it's advantages/disadvantages would be.
  2. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Hi, yes, and it's quite usefull, this enables Direct SIP Calls, so you can make a reaceive calls by using this format. SIPID@SERVERIP_DOMAIN .
    It's explained a bit better here.
    https://www.3cx.com/blog/voip-howto/direct-sip/
    Cheers
  3. Techops
    Feb 5, 2018
    30
    Thanks. That's the post I read about.
    You note that it enables the format SIPID@SERVERIP_DOMAIN. What's the method if Direct SIP isn't enabled? I thought that Direct SIP would circumvent the 3CX server but the blog link doesn't seem to corroborate that.
  4. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    932
    151
    Direct SIP doesn't circumvent the 3CX Server, it circumvents the trunk. Think free calls a la Skype.
  5. Techops
    Feb 5, 2018
    30
    Oh! That makes sense. Thanks much.
