Direct support for Hardware Gateways
Discussion in '3CX Phone System - General' started by dionh, Apr 3, 2007.
  1. dionh
    Mar 3, 2007
    23
    Do the 3CX development team plan to implement direct support for any BRI/PRI or analogue PCI/PCI Express cards into there software.
    Kind regards,
    Dion
