Directed to Vmail
Discussion in 'iOS' started by Mick101, Oct 31, 2016.
  1. Mick101
    Oct 31, 2016
    6
    Device Info
    Phone Model: iPhone
    Generation: 6
    Firmware Version: [ios 10.1]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]]
    Connection: [WiFi]
    Server: [Internal]
    Observing a strange behavior on the iPhone App with V15.
    When making an internal call from an ATA phone (ext 2001) to a 3CX iphone app (ext 1978), I answer the call on the on the iPhone but seconds later, the iPhone app opens a second line and calls the voicemail.
    Have tried with a few extensions so far but the same behavior. Has anyone seen this before and how do I solve this?
    FYI, this is only my 3rd day with trying 3CX.
    Thank you,
  2. Mick101
    Oct 31, 2016
    6
    New Update:
    I managed to get a test Android phone and installed the 3CX client on it.
    Calls received on the Android client doesn't have that behavior.
    I am assuming that this a unique issue on the iPhone. I will uninstall and reinstall.
    Update: No change after uninstalling and reinstalling. Definitely something wrong with the iPhone app.
    Tried installing on an iPad Mini with iOS 9. Same behavior but I also don't get a Presence Status. it flashes "Forbidden"
    Log shows:
    11/01/2016 9:27:33 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 127.0.0.1:5080 tid=PjiMb...
    Although I can make and receive calls.
    iOS Client seems to be very buggy.
