Directory / Phonebook Gigaset
Discussion in '3CX Phone System - General' started by mercury3, Jan 3, 2017.
  1. mercury3
    Apr 11, 2016
    19
    I would like to set up the automatic directory on my Gigaset DECT phones. For this I add an XML directory (phonebook.xml which is in the provisioning directory, in fact I tried all XML files) in the configuration of the terminal (N720 IP PRO) but it does not work. The tags used must be specific to Gigaset but I found nothing on their website.
    Has anyone ever managed to make it work?
    Thanks in advance !
  2. mercury3
    Apr 11, 2016
    19
  3. rb1
    rb1
    Nov 17, 2016
    18
    Hi did you manage to do what you wanted? if yes how? I am trying to do something similar.
  4. mercury3
    Apr 11, 2016
    19
    I found a solution, I created a vCard file (.vcf) with the list of my extensions that I then inject into each DECT through the N720 DM interface. It's a bit tedious.
    But apparently the automatic directory would be under development and will be available in the next 3CX update.
